Hopefully someone can give me some advice.
I am in a flat on the 4th floor of a building and looking to have a gas boiler and central heating installed. The central heating would comprise of 6 or 7 radiators and the flat is 80 sq m.
The gas meter is located at the front of the bottom of the block, the pipe from there then runs to the back of the building under the communal stairwell. Then up the back of the building and back inside to the flat. The pipe run from my measurement is in the region of 30-35 meters in total (with it being around 24 metres up and around 6 metres across) with about 5 right angle turns and I'm unsure on the number of other connections.
The pipe diameter is 22mm from the meter into the flat and that is accessible, it then goes down to 15mm on the way to the gas hob.
My question is assuming the gas supply from the meter is around the standard, which I understand from reading this forum is around 21 mbar, would a Combi Boiler receive a adequate supply of gas? As I would assume not form what I've seen on this forum but the people I've had round to quote seem to think otherwise.
So far I have had four people provide quotes, 1 recommended a 28w boiler when I raised the gas flow they replied that they have fitted them in similar flats and they work fine. 1 mentioned the gas may be low coming in so I should only go for a 24w boiler that works down to 13mbar. Whilst another again mentioned the gas and said a Ideal boiler would be best as they work well with poor gas flow. The last said from his calculation a 9w boiler is all that could be supplied sufficiently, so a small boiler with a water cistern would be best.
The gas pressure hasn't actually been tested, I'm not sure how they would be able to test it as there does not seem to be a valve that can be seen unless there is someway to do it via the gas hob.
Thanks for any advice you can give.
