CENTRAL HEATING LEAK SEALER.
12 Apr 2008
Merseyside
Combi boiler central heating system.
I have a number of small leaks on the pipework to various radiators around the house.
The system is only three years old, and 10mm copper tube has been used. I was thinking of using fernox leak sealer to cure this problem and save myself a lot if work. Has anybody used it with any success and does it last any length of time?
Help appreciated. Gary.
better to repair leaks if you can, i have had a couple of combis that have blocked up badly after leak sealer was used, to be honest i've never used it. I think you should repair leaks if you can see them.
Thanks for the advice, I think I will repair the leaking joints as you suggest, and not take any chances with the sealer.
Cheers. Gary.
