Hi
Appolo boiler
changed the thermocouple a few months ago as pilot light went out would not light. Had a few mvolts on there, but forum advised changing and this solved the problem.
Here we go with my new problem
hot water works fine, and seeing that I messed about with the motorised valve upstairs a few years ago ( cant remember why ) when the hot water was on, the radiators would get warmish. This has been like this for a few years. I am at my partners house most of the time, so not worried about this.
Anyway here we go. With the switch set to hot water, the boiler fires up and heats as normal. If I turn on hot water and heating, with the stat turned up high, the radiators dont get any warmer, just the same warmish.
The room stat clicks , so should be sending the signal.
I went upstairs to the motorised honywell valve and pushed the leaver so that it locked in the shepards crook end if you see what I mean.
The radiators worked.
Let them work for a while, and then turned the stat down. After a few minutes the boiler/pump running noise stopped, so appears to be controlling
What signal does the motor get? from a relay? where can I measure it?
how many ohms should the winding measure? accross what wires?
if i just bought the motor, how do I set it up in the correct position, so that I know if its shut etc, or is it easier to buy the whole unit?
Thanks for any help given
Nick
Appolo boiler
Nick
