I have recently had a new system boiler fitted and the heating comes on when it is switched off. The hot water is timed to come on twice daily but whenever the water is on then the heating comes on even though it is switched off. I have had a replacement valve fitted and its still the same problem. I have now also discovered that I cannot control the heating with the room thermostat as I used to. It will not operate if I try to turn the heating up. Also if it is outside of the two timed settings with both hw and ch on , I used to just put the programmer to 24hrs and turn ch on with the room thermostat but am unable to do this now. The upstairs radiators dont seem to come on at all. It seems that the ch doesnt come on if there is a full tank of hot water so I have to run hot water off in order for the boiler to fire up. Basically, I cannot have ch when I want it to come on. The only thing I have got is a tank of hot water and slightly warm radiators when the hw is on, regardless of whether ch is switched on or off. They have been back 5 or 6 times at least and are unable to fix it. Anybody got any ideas?
