Foreword: I've already replaced the 3 port valve head...
- Boiler: Potterton Flamingo 50s
- Controller: Potterton EP2000 > EP2
- Room stat: Old brown Honeywell > T6360B
- Honeywell Mid Position 3 Port Actuator/Valve
I moved into a 1980’s house with an old EP2000 controller, which only allowed both HW and CH to come on together, not independently. So I decided to switch to a newer EP2 controller.
The boiler clicks and fires up no problem and the pump runs when the hot water is switched on and gives hot water, but if just the Central Heating is selected, there is nothing at all from the boiler and the pump does not run.
Central heating will only work when both HW and CH are on.
From the forums, it appears the 3 port valve head is a common point of failure. The test lever sprung back to position with ease so it didn’t look like a stuck valve. When set to MAN, nothing happens, no boiler or pump reaction.
I changed the head for a new one anyway, however it still behaves the same way!
Anyone know have any ideas? Could it have been wired up to behave this way?
