I am totally perplexed on this one and hope somebody can help
I have a pretty standard pumped heating system. I have a programmer, room stat and gas boiler. The heating is set to timed, for on a 7.00am and off later in the day. The system has been fine set to off all summer, hot water working fine. My wife set the prog to boost one evening last weekend, and now we have a problem. The heating kicks in every morning, even when the programmer is set to off, and even when the room stat is set to 0. I have changed the programmer yesterday (Grasslin QE2) but this has made no difference. Howver when you move the room stat and the programmer into various positions and then back to off and 0 everything then shuts down as it should. With the room stat on 30 and the prog to off nothing happens, the prog to timed and the stat to 30 the boiler fires, the stat to 0 the boiler stops. So set to off on the prog and 0 on the sta all will be fine until tomorow morning at 7.00 when the boiler will fire again.
Any ideas?
Any ideas?
