Hi all
I have a combi boiler - WORCESTER 28i junior
There's a switch next to the boiler (with a neon light when turned on) and this is left on in order to get hot water when a tap is opened.
I have just moved into the new house
The hot water is great - not too long to reach taps and v hot. But there is no heating (i tried to test it but there is no timer or room thermostat)!
I have the boiler manual and it says - for a programmable room stat installation, a NEUTRAL wire from the prog room stat should go to the NS terminal at the boiler , the Live wire to the prog room stat should go to the LS terminal at the boiler and the Switched Live wire to the prog room stat should go to the LR terminal at the boiler
Is this correct? What I mean to ask/clarify is: if I buy a prog room stat and it required no neutral wire (ie has a battery instead) to i just need 2 wires to the boiler/prog room stat??
Also, is the Live connection to the prog room stat from the boiler (also known as a COMMON terminal) and the switched live from the prog room stat to the boiler, also known as the CALL terminal - as when i wired in a standard room stat in my old house about 3 years ago, the common and call terminals were used (and i'm presuming its just different terminology for live and switched live??)
One last question - with a standard boiler, all the wiring, ie from the 3 port, room and cylinder stats, programmer, mains live in, switched live to pump and boiler are all wired up together via a wiring centre. With a combi boiler, and only wiring is required for the heating side, does the heating circuit get its power directly from the boiler, due to the boiler having a permanent live to it (which is also required for the h/w to work instantaneously)??
Thanks for reading, sorry if I sound v confusing!
