central heating
22 Nov 2007
Gloucestershire
put on new honeywell V4044C diverting valve,now having problems with central heating (not heating all rads). hot water only coming out warm not hot. i'm stumped,any help would be most welcome
Much more information required. Please.
Did you drain down? or just change the head? have you bled all rads and the pump if you drained down? ...
Bleed point near the HW cylinder?
never bled cylinder only radiator system
Presumably you meant to say that you didn't drain the cylinder- ??
The blue pipe is part of the radiator system and needs bleeding.
