central heating
27 Feb 2010
looking to install a manual summertime lever valve to only operate either the dhw or ch &dhw.
would like to know how to install this valve.
do you need to install extra pipework or is it simply installing on to the flow of the first rad , or is it a matter of installing a new flow & return before the lever valve to bypass.???
Why do you need a manual valve???? this can all be done by setting the programer....
i know it can be done by the programmer but not a single channel which is there at the minute.
i sorted the problem by installing a 3 port mpv and a dual channel programmer.
thank's for the reply anyway tininho
