I have just had a new pump fitted to my Baxi Bermuda back boiler. The previous pump, according to the plumber the faulty pump was very old, probably original circa mid 70s?
The problem is now the heating pipes make banging and clanking noises when heating up, and periodically when switched on. This is different from the creaking due to expansion.
Prior to the new pump installation these noises didnt occur.
The highest radiator (towel rail type) requires a slight bleed every couple of days, but only for approx 5 seconds.
After reading previous posts it seems there could be air being pulled into the system or the pump is set at the wrong speed, is this the case and what is the best cause of action to stop being woken up at 5 in the morning (yeah, I know to keep the CH off!!)
FYI the boiler is downstairs, hot water cylinder is upstairs in the bathroom and all the other tanks are in the loft.
I have tried turning the boiler setting down a little which seems to help (now on 2.5 (out of 5), was on 3.5 before).
Thanks in advance for you help
