I'm struggling to keep both the heating and hot water system running. For some time the Lounge radiator has been slow to heat up. About 6 months ago I bit the bullet and got a plumber to investigate. He changed the pump (to a Grundfos 15/60 Super Selectric) and balanced the radiators. He had real problems getting it sorted and in the end most radiators were turned right down to just a crack open.
For most of the winter all was well but now I'm getting (mostly) cold radiators. I can fix it by turning off the Hot Water circuit which diverts the flow to the radiators (albeit slowly). Just once I've woken up to cold water and perfect radiators (my theory is that the first circuit to demand gets the flow)
The system also has a gate valve for bypass (2 Honeywell valves) which is screwed down almost closed to get the flow in to that lounge radiator.
The radiators all heat up together when working. I leave the hot water system on overnight to fully replenish.
Have I ruined the pump by having the gate valve screwed down to far or have I got blocked pipes?
