I posted an earler thread here related to a problem with my CH system and followed the advice. However, I think the problem is a little more serious and I would like the opinion of some of the regulars on here before I go chopping the system around.
Original issue was (and still is) air in the system causing major clanking and banging in the boiler. (Glow worm Ultimate 120FF open system). I assumed poor flow so flushed the system out. All started OK and then back to the old state. Very little muck came out and there don't appear to be any blockages.
Now, I have been away a couple of times over Xmas and away from the house for a few days at a time. What I have noticed is that on returning to the house after a few days, water is still being taken from the header tank! My summary - I must have a leak somewhere. Now there is no evidence of any leaks in the house in ceilings etc. and the amount of water taken must amount to a fair bit (10's of gallons a day). The only place I can think of that it must be escaping therefore is the hot water tank (leak in the coil - but no discoloured water or other evidence there) or into the ground where all the downstairs pipes run in the concrete floors - this is my bet. Pulling the floors up is not really an option as expensive tiles and wood were laid over the top eariler this year.
On reflection the CH has never worked well and maybe the problem has always been there. My plan is to replace all the pipework downstairs by running in the ceiling space overhead and renewing the rads at the same time. It is a major job but at least the upstairs is half ready with boards up etc. so it could be worse.
This weekend I plan to firstly confirm it is not the HW tank by draining the water out and seeing if it refills with CH water then isolate the downstairs CH system which is a pain as it is 28mm pipes fitted tight against a wall to confirm this is the problem as the system should not keep draing water if the leaking section is removed.
I have a few questions:
1/ Do you think my diagnosis is fair given what I have said? - I simply can't think of any other explanation. Is their any way of pressure testing a section and what gear would I need?
2/ If I go to the trouble of putting in a new system downstairs would you go to the trouble of putting in a seperate zone?
3/ Would you use plastic pipe as this would make routing a lot easier or would you use copper?
4/ What is a decent TRV to use as most of the ones I have come across in the past stick for a pastime?
