I've just spent the weekend installing a Danfoss Heatshare pack, new pump and TRV's to all the rads (except 1).
All plumbed in and all works with no leaks - just a few questions now!
Q1. What Speed Setting should I put the Grundfos 15/50 pump on? I've currently got it set on 3 (the fastest) - is that correct? - I have 8 rads in the house, what would having it on too high or too low do?
Q2. Since installing the kit the rads are much hotter than before - too hot to keep your hand on (before I couldn't get them that hot). What has made them that much better? Is that just the pump?
Q3. As above, what's the best way to reduce the temp? I can either turn the TRV's down or turn the dial down on the boiler - which is more efficient? My idea was to turn the boiler down first then adjust each room accordingly - is that correct or should I leave the boiler alone and just adjust the TRV's?
Q4. With the kit I got a cheapy room stat, I've also got a Digital Room Stat which I was going to use but the wiring seems different. The manual one has 3 wires going to it - (N COM CALL). The digital one only has two wires (NO NC) - the digital one has batteries which go in it so my guess was I don't need the N one? If that is correct which do I connect the others to?
Q5. The instructions talked quite a lot about boilers with overrun being better. As far as I am aware my boiler doesn't have overrun (it's never overrun before - the pump and boiler both instantly switch off) so I've wired it up as per the diagram without overrun. Is it any major disadvantage to not have overrun?
Here's some details to help:
8 Rads in house
House is 4 bed detached
Boiler is a gloworm probably 30 years old (can't remember model but it's something like 380)
Problems before were:
Pump was noisy.
Central Heating and Hot water always came on together before
Heating just kept heating there was nothing to stop it at a given temp
Hot Water was getting scalding hot during winter
We had to have the heating come on during summer to heat water or go round and switch off all the rads
8 Rads in house
Pump was noisy.
