Hello all. Steve here, desperately needing info if anyone has it please?
I have a new PCB for my SE80 but the fan/pressure switch/thermostat connector block has 1 pin more than that which it is replacing.
Background:
4 weeks ago I got the dreaded lockout flashing code 60 (ionisation pcb fault). Reset would usually cure it for a couple of days. 2 weeks ago it became so frequent I decided to order a new ionisation electrode. If I'd got the last digit of the part number correct I would not have received an ignition electrode instead
. I ordered the correct part and fitted it, along with the unrequired new ignition electrode.
Of course, that turned out not to be the fix I was hoping for. Same fault, although that's only required a reset once in the past week - I'm sure I disturbed something when I cleaned the board, so I'm assuming it's a dry joint somewhere, but as it's currently working I fancy leaving it installed until I get time to install my replacement.
Talking of which, I have just taken delivery of a brand new pcb (61308723) to replace my existing pcb (1302265). The sparse documentation that came with the new unit does indeed say it is a direct replacement for 1302265, and all in all it looks like it will fit - LEDs are in the right place, pots line up fine, though the overall look is different as I would have expected seeing as mine is 9 years old now.
So...
My current pcb has an 8-pin connector block for the fan, pressure switch and safety thermostat. The brown/blue fan wires are separated from the other 5 by a blank [unused] pin (pin 3)
The new pcb has a 9-pin connector block which also has pin 3 unused.
My question...
Does anyone have a diagram, or can list for me, which pins on my new pcb I need to connect? Although I'm sure the existing push-on connector will easily clip onto the new pcb, there will remain an unused and exposed pin (pin 9) and I'm not happy doing that.
If it helps, this schematic is from my existing maintenace guide:
[code:1]
01 brown
02 blue FAN
04 white
05 orange PRESSURE SWITCH
06 black
07 brown
08 brown SAFETY THERMOSTAT
(09 green/yellow MASS)
[/code:1]
(The green/yellow "MASS" is not actually a pin but is a flying earth, see pic)
I'd be grateful for any assistance you guys or gals can provide, and am sorry for the lengthy post.
Here's my current pcb showing the 8 pin connector
Here's the conn block of the one I received today
Background:
So...
My question...
[code:1]
01 brown
02 blue FAN
04 white
06 black
07 brown
[/code:1]
