Changing a Satchwell TL for Drayton Digist +3
30 Jan 2011
Surrey
Currently I have a dedicated gas boiler that is used for central heating only and programmed via Potterton EP 2000. The thermostat is a Satchwell (about 15 yrs old I think and the one I would like to replace).
If I was to switch the Potterton EP 2000 to constant and use the Drayton Digistat +3 to control the central heating would this wiring detailed below be correct, given my existing wiring set up:
wiring for the Drayton Digistat +3
RED Live to common
YELLOW Switched Live to Call for Heat
BLUE Neutral to a terminal block
Earth to another terminal block
Existing Satchell Stat wiring
Red 3
Yellow 1
Blue 4
Earth Wire
Thanks. Steve
