That may seem the obvious answer but is incorrect. There are certain materials used on older cars (leather for a start) that will suffer & deteriorate dramatically from storage in a zero humidity environment which would be practically impossible for you to realistically achieve anyway; what are you trying to achieve?zero i would have thought. the less moisture in the air the better.
I’ve owned a TR6 since 1975 & did “nut & bolt” concourse standard restoration over more years than I care to remember but it’s been finished & driven since 2004. It lives in a well ventilated garage with a high quality breathable cotton cover over it & although it's probably no longer worthy of a concourse ticket (not without a bit of work anyway), there has been no appreciable deterioration in the quality since then & certainly no rust. There are controlled environment storage systems you can buy; the one that immediately springs to mind is “Carcoon” (basically a big plastic bag with a fan & filter on it). Humidity is not the only factor; good ventilation will work just as well & you need to avoid large changes in temperature at all costs if you’ve no humidity control, this is what causes ambient moisture to condensate on cold steel; in some instances a background heater can be just as much of a benefit as a de-humidifier!
Some pics in my profile if your interested in lookingnice car the TR6 BTW, my uncle has one.![]()
I've owned my car since 1975, have been a member of the TR Register for nearly as long & a daily contributor to the excellent TR Forum from 2003 up until a year ago & my advice is to be very, very careful of what’s on offer on E bay or any other auction for that matter. There have been numerous instances of scams involving members & even a dealers car being offered for sale which (to those that know) clearly aren’t genuine & the whole purpose is to rob you of your cash, one way or another. Just this weekend a valuable TR5 was stolen from a classic car show in Essex & who knows where that will end up; but hopefully it will still be in one piece.I now find myself often on e bay looking at them, and dreaming. Don't get many for auction up here.
