CM927 7 Day Wireless Programmable Thermostat
7 Dec 2012
Manchester
Can I set this to come on at 6am for 2 hours and then come on at 5pm for 2 hours? Confused.
Thank's stem, but what do I do with the other 4 periods?
Yes, you can set up to 6 different periods each with different temperatures if required per day.
Full operator instructions can be downloaded by clicking here
If you don't want them, just set the temperature to a low value at these times and the heating won't come on. I have my thermostat set to 17 degrees when I don't want it on (It is normally 20 degrees) most of the time that keeps the heating off, but very occasionally when it's sub zero outside, it does come on for a while, this just keeps the chill off and helps with a quicker warm up in the evening. If you don't want it to come on at all then use a lower value.
P.s. Welcome to the forum curlray, but don't edit your original post with new questions. Use the "Post Reply" button (below left) to add it to the bottom of the thread, otherwise it may not be noticed.
