Hi all!
I was wondering if anyone on this site can help me with what I describe as a mind-baffling problem. I live in North Belfast (BT14 6NQ) and my main transmitter is Divis (UHF C21, C23, C24, C26, C27 & C29). I am in the position where I also receive from Black Mountain and receive the UHF channels (C42, C45 &49) along with the Northern Ireland mini-multiplex - UHF C39. As for transmissions from the South of Ireland I receive Saorview from Clermont Carn on UHF C52.
I recently rewired/upgraded my television signal distribution system using RG6 co-axial cable (by Kontrakt) and a new Philex SLx Distribution Amplifier, 8+1 Way, 27824R (each outlet is 20dB gain). Four of my five cable runs are working fine and I receive all of the above channels. The cable run I have a problem with is < 70 feet (just over 21 metres) and the typical loss for the cable type would be in the order of 3 to 4 dB.
The equipment at the end of this run is a Bush DVB680 Freeview HD Digital Set Top Box (this box has a DVB-T2 tuner) along with a Toshiba DVB-T television set. I can tune UHF C21, C23, C24, C26, C27 & C29 from Divis, C39 from Black Mountain along with C52 from Clermont Carn at the other four points throughout the house but I cannot tune C39 (from Black Mountain) and C52 from Clermont Carn. All other channels are of good signal strength and quality. I have inspected the cable run visually and cannot see any problems. Any suggestions as to what could be wrong!
Regards
P. Kieran Ward
Regards
P. Kieran Ward
