Hi, have a Vaillant Eco Tecplus 624 system boiler with megaflow. Has 3 zones : one for room radiators, one for hot water and another for towel rads. Boiler has both internal and external expansion tanks attached. Complete system was installed 2 years ago.
Over last couple of days have found that downstairs radiators are luke warm or stone cold whereas upstairs the rads are giving off heat as normal. Up until 2 days ago, all rads were producing heat as normal.
This problem seems to happen when I have heating on (for room rads) at the same time as hot water or towel rads being on.
If only heating for the room rads is on, then all rads (upstairs and downstairs) are giving off heat as normal.
Also found that when heating and hot water are on, then upstairs hot water is not as hot as I expect it to be.
Any experts out there have any suggestions for possible problems? External pump was replaced about 4 months ago.
Have bled all rads - found a bit of air in the towel rads and topped up external expansion tank so that pressure is about 1.25 bars (just above red needle).
Have had BGas round as I have Homecare agreement but their engineer thinks that system may be clogged up and hence hot water not getting around everywhere when both heating and hot water are on at the same time.
He recommended Powerflush to remove blockages - would others agree with his conclusion or are there aspects of the system to consider, eg. zone valves, pump, heat exchanger?
Any suggestions/help would be most appreciated especially if Powerflush doesn't help.
Thanks.
Thanks.
