- Joined
- 8 Apr 2005
- Messages
- 4
- Reaction score
- 0
- Country
I've got a problem with my rads Recently, I put a sludge remover in the system and left it a couple of weeks. Every thing worked perfectly during this time, hot water, hot rads and I might also mention that a new pump was installed at the same time the chemical cleaner was introduced to the system.
The problem occurred when I drained the system down to flush out the sludge remover and add an inhibitor. Everything seem to be going to plan until I fired up the central heating. The pump clicked into life and heated up very quickly however, the supply pipe leading directly from the pump that, I assume, propels the hot water round the rads, was cold, as were all the radiators.
I found one massive airlock in an upstairs rad, which was successfully bled until water manifested itself from the bleed screw. Having checked every other rad for air, decided to fire up the boiler but again, nothing.
The situation stands as this, no problem with the hot water but all the rads are cold, including the rad feed from the pump itself. One side of the pump pipe work is boiling, the other is freezing. Can't find any airlocks in the rads, whats going on
Any help would be really appreciated, thanks.
