First of all, thanks in advance for all who read and respond. I tried doing a search in the archives, but couldn't find any answers there.
The water system worked fine UNTIL we had a pipe (labeled HOT on the piping) burst under the uppermost level floor. Upon discovering the burst pipe, I did the following:
1. Turned off the combi boiler;
2. Closed the supply gate valve directly beneath the combi;
3. Shut off the water supply at the mains
After repairing the burst section, and restarting the system we now have the following:
4. Hot water flow and pressure is fine.
5. All radiators work and heat as normal; we checked each one for air and there was none in any radiator.
6. Combi pressure is at about 2 bar.
7. However, there is now NO COLD WATER in any tap within the house. We do have an outside cold water tap that works fine...it is just there is no flow of cold water inside. This outside tap is on a separate feed from the cold water lines in the house, so I now we are getting cold water from the main.
Any suggestions as to what steps I should take?
Thanks again. I'll look forward to any help you can give me.
