Combi Boiler Constantly Cuts out and relights
1 Oct 2009
Yorkshire
I've a problem with my Jaguar (rebranded glow-worm) boiler that I'd like some advice on. When ever we turn the hot water on the boiler will light, stay on for about 5 seconds, then go out, relight, stay on for 5 seconds then go out. It will do this for about 5 minutes maintaining just about a luke warm temperature and then eventually will stay lit and rise to the correct temperature. I think its the same when the heating comes on too, but tis hasn't been on much over the summer so not really tested. Any ideas what would cause this?
Honeywell ignition board fitted on these i think. Sounds like a fault these do. Had the same on a saunier duval
Also check flue is ok in case boiler is smothering. May be rectification on pcb (if it has one)
