I had a hot water and central heating system installed in a house in Italy last year. The boiler is a Simat Combi with a 60litre internal hot water tank.
The mains pressure outside the house is as far as I can tell is 6 bar. I was told a pressure limiter was fitted because of the high water pressure.
The trouble is that in the Summer when I only use the hot water everything is OK, but when the heating part of the boiler is also turned on in the Winter as well as the hot water at the same time, the pressure relief valve on the underside of the 60 litre tank lets cold water out when it starts up and drips on and off all the time about 4 to 6 cupfulls a day.
I am trying to get some idea of what might be causing this before calling out the so called boiler expert who does not seem very clued up at all!!
Any suggestions would be gratefully received.
