I posted s imilar question a while ago but have got more information - which I hope will lead to an answer.
I have a Potterton Puma 80 combi. Water pressure is good - 3.5 bar. Cold water flow is 16 l/m. Hot alone is around 8 l/m. However when both the hot and cold are run together the hot flow reduces to below 4 l/m.
At this flow the boiler keeps cutting out (presumably as the flow is too low), so not only does the hot water end up being low but it goes in waves of temperature.
I had a couple of plumbers around. One said I needed to move the boiler to the centre of the house but that I may just have to live with it. The other said that a new boiler should sort it. He recomended a Potterton Gold 33 HE A which including fitting would be £1,150.
Which is right? And if a new boiler is that model and price good?
Thanks,
Jim
Thanks,
Jim
