Hi all,
Had a (hopefully) straightforward question about the differences between a modern shower mixer and old school individual hot and cold flow taps.
I have decent flow and pressure, and the readings in our yet-to-be renovated bathroom are:
Hot: ~12 l/m
Cold: 18-20 l/m
Average mixed flow: ~16-17 l/m (good enough for me)
Pressure: 5 bar
Our second bathroom was recently renovated and fitted with a Hansgrohe ShowerSelect (2 outlet) shower mixer (it's a manual mixer; not thermostatic). There's no flow control lever, just a button to start the shower and a temperature lever. The average flow rate at the same temp in this shower is 12 l/m (so a drop of around 4 l/m), which doesn't make sense as it supports a high flow rate at the mixer and shower heads.
The bathroom that hasn't been renovated yet has a tub and separate hot and cold taps, with attached handshower, yet has a higher flow rate. To get the 16-17 l/m flow rate, we're opening the hot tap all the way and then adjusting the cold water to get the desired temp. This way, we're getting the most hot and cold water mixed in.
As there's no flow lever in the new shower, I wanted to know if all these mixers (without a flow lever) work by using less cold and hot water to get the desired temperature. If so, is there a way of overriding that to get the maximum volume of both hot and cold? Can we retroactively adjust the new shower through the mixer (by removing the mixer panel) for more volume or do these mixers generally work this way by using less water?
The Hansgrohe mixer has a maximum outlet flow rate of over 20 l/m at 3 bar.
Hot: ~12 l/m
Cold: 18-20 l/m
Pressure: 5 bar
