I wanted to gain some opinion on changing from floorboards to a solid floor.
Background - a chimney has been removed and the walls and ceilings have also been stripped back to brick. After some inspecting it seems some odd occurrences have occurred in the house, the floor joists are either rotten, uneven, or simply don't actually bed into the internal brickwork of the house.
While I also wish to install a stone floor and some underfloor heating in this area it was suggested that the simplest thing to do is remove the joints and concrete over.
After doing some research and reading quite a bit I am a little overwhelmed.
The issue - The depth of the void under the boards is around 500mm, the intention is to use the paster from the walls and the tiles in the kitchen along with some brickwork as compacting material to be berried under the boards firstly.
This is where I have differing opinions - I have seen that some use ballast material thereafter to build and even a sublayer before applying membrane, then concrete, then insulation then a screed (this is of course without the underfloor heating).
Others use building sand, what is most appropriate and what are the sizes of each of the layers that should be used?
Oh and the room measures 6.5m long by 3.2m wide.
