Hi all. I'm hoping for any advice.
I had a brand new baxi main condensing boiler fitted. All was well until we had a flood recently, which poured over the boiler fo a couple of hours. Afterwards. There was a low voltage error on the boiler. After letting the boiler dry out and resetting it, It began to work again. But i have noticed that recently when the boiler pre heats the water at times it thinks i may use it. I can hear a quick loud noise like a pop of air through the flue followed by a small amount of water that is spat out of the flue. It then performs as normal. Any ideas what may be causing this?
Thanks in advance.
Dan
Thanks in advance.
Dan
