Connecting a Honeywell Detector
4 Dec 2011
Merseyside
Hi, I am trying to connect a Honeywell Dt 7550a Dual Tech Detector to my existing Honeywell Galaxy G2-20 Alarm system,
And was just wondering where the connections go, on the panel there is only 2 connections out for alarm + and - and then the power as well, but on the Pir there is Power C Nc And EOL so was wondering where these connected to the alarm.
Obviously I know about the power. But the rest I am unsure about, anyhelp would be much appreciated.
Thanks, Matty
Panel + and - ???
There are zones marked 1 2 3 4 5 6 7 8 9 10 11 12
The pair goes into one of them and they share a leg. So for example the pair would go into 1 and 2 for zone 1001 and 1002 would go into 2 and 3.
Detector, use the same pair, one leg in N/c with a 1k resistor, the other leg of the resistor in the C with another resistor going to T, then put the other wire into the other T.
Obviously the other pair for power.
Sorted.
Just to reopen this, for zone 2 then would the same go but instead to connect the two pairs to 2 & 3?
Matty
With the shared negative rail leg.
You DID say you understood this?
Oh yes I understood it because for zone one was a pir in my hall way for final exit and the rest were all wireless zones so I didn't need to know how, but now I'm just wondering if I added another detector for zone 2 which is empty. So was I right then it's just the same pattern over again ect?
