connecting boiler to circulate heated water through geyser
28 Mar 2010
Hi, i have a FrancoBelge stove/fire place that have its own 2 liter boiler. I want to fit the pipes that the heated water circulates through my geyser (600kpa geyser) to save energy. Is this possible? I have a solar 12V pump already that circulates sun-heated water in summer.
No response ??? oh well , if the question is can a solid fuel boiler be connected to another boiler , that use's a different fuel , well yes it can ??
providing certain criteria is met ?? the baker , dunstan neutralizer , is a piece of kit designed for this purpose !!!
Dunsley Baker neutralizer!!!( not dunstan oop's )
thanks transam, ill go see what the Dunsley Baker neutralizer is about. What i did not say, but meant, is that i want to circulate the boiler's water through my normal household, electricity heated, geyser, and i want to confirm that the current geyser will be able to handle the pressure and if anyone had suggestions on the pipe configuration, as well as if a 'plastic' solar pump will be able to handle the near boiling water coming from the little boiler. Sorry for this rather lengthy explanation. Thx for your reply
Hi Johan have you had any sucsesse in connecting the stove to you geyser and did you have any problems?
