Connecting to an existing salt glazed system
26 Apr 2005
I have a mid 60’s property with the original sanitary ware. The downstairs loo is cemented directly into a salt glazed stand pipe, feeding a salt glazed foul drain, buried in the concrete floor. I am about to modernise & add a shower cubicle or, preferably, a walk in shower flush with the floor. The existing W/C stand pipe is set too far away from the wall to accept a modern cistern so it will need to move + the shower will obviously need a waste connection.
The existing drain runs the full depth of the house into an inspection hatch around 8 meters away in the back garden so providing a new, PVC drain is not the simplest of solutions. I am unsure of what I will find when I dig up the floor & concerned about how to go about connecting to the existing system or even if this is possible.
Is it be feasible to remove & replace the existing stand pipe with a modern PVC one, closer to the wall & is it possible to connect this to the existing salt glazed drain pipe? Where do I connect the shower waste (1 ½ m away) into the existing system – i.e. do I need to go before the loo or can I take the shortest route which will bring it after the loo? There is an existing sink waste connected before the loo but it disappears into the concrete floor so I am unsure how this connects into the existing system, should I connect into this? Is it likely to be enough depth to do this?
easiest way is to fit Y branches under the floor, run the pipe to under the shower and using an adapter reduce the pipe down level with the floor.
If you wanted a walkin shower you could fit a floor gully into the finished surface
Are you saying that old salt glazed soil pipe sytems will accept new style PVC fittings allowing me to connect a new shower drain to it & replace the W/C standpipe as well?
I didn't say that, but you can indeed get convertors for salt glaze to plastic
Perhaps I went on a bit in my original post but I was mainly concerned about accessibility & compatibility of modern PVC products with the salt glazed stuff, many thanks for clearing that up. I have since established how deep the soil pipe is within the screed & I should not have any problems with connecting the shower waste either so all I have to do now is get the Kango out!
