Hi everyone
I have just had a Worcester 30CDi system boiler installed in conjunction with a Megaflow 125 cylinder. The central heating is controlled with a DT10RF room thermostat and the hot water by a timer fitted within the main body of the boiler.
I am trying to find out if there is a way of controlling the temperature of the hot water using the Megaflow's built in thermostat. The Megaflow is currrently connected to the boiler by a temperature sensor which I gather is required by law to ensure the megaflow doesn't overheat. But this doesn't allow me to control the temperature of the hot water.
Does anyone know if there is another connection on the boiler that can be used for this or suggest another solution. There is of course the hot water control knob on the boiler, but even down very low, it still produces hot water at 75 degrees C.
Thank you
Roger
Thank you
Roger
