Hi
I had been busy doing a new kitchen in my house, 1930.
During the work, I add a new fusespur spur from a downstair ring main for a washing machine, checking the rest of cables to lighting, ringmain etc, discover that some of cables are from 1970, some from 1985, and got a old 6 way rewireable fuse board with a sep. RCB 30MA trip on meter tails to board. I have a electric cooker and it connect to a cooker/socket switch which also connect to a fan unit via a 3amp fusespur in 2.5mm T+E. The cable for cooker to fuseboard is 10mm T+E cable. Is this correct?
Also I have a 9kw mira sport I fitted 2 years ago, The cable run from fuseboard protected by 45a trip to pull cord switch to shower and within 9 metres long, no problem. Now I would like to use a imm. heater, but no spare fuse.
So is it time to rewire 3 beds house? At the moment, I replaced all rewireable fuse with trippers as a temp.
How many fuse way do I need? I have to have a spilt load unit.
Hope this help.
1x shower 6mm new cable
2x ring main 2.5mm
1x imm. heater 2.5mm
2x lighting main 1mm
1x garage main 4mm new cable
1x cooker main 10mm new cable
Hope this help.
2x ring main 2.5mm
