i have installed 10 mm t+e cable from the cu to the main cooker switch. then from that socket i have run 2.5mm cable to a socket which goes behind the cooker is this ok? or should both lengths of cable be 10mm.
the cooker wiring instructions says it has to be fixed wired to the wall . so i assumed would it be ok to run 2.5 mm flex from the cooker to a connector block which would then be connected to the 2.5mm cable in the wall ?- (2.5flex - 2.5t+e - 10mmt+e) that the order .
hope this makes sense.
