Cooker Hood external ventilation
13 Aug 2008
Tyne and Wear
I'm thinking about putting a conservatory on the rear of my house (6 years old). Problem I have is the cooker hood external vent would be within the structure of the conservatory, I understand that this is not permitted? Does anybody have any solutions or ideas to resolve this issue?
No you can't vent into the cons. it will stink of cooking & grease will congeal on the ceiling panels. I had the same problem; luckily my joist run was in the right direction to allow ducting above the ceiling between the joists to an adjacent external wall (Marley rectangular ducting). If you’re not so lucky with the joists, all you can do is duct below the ceiling & box it in but obviously this may be noticeable.
Thanks for the reply, unfortunately my ventilation is already concealed within the ceiling. My cooker is not on the external wall but against an internal wall opposite the external wall, with the ducting already through the ceiling to the external vent. What to do? :?
What to do? :?
Move the cooker to another external wall :?:
You could go up through the cons roof or sideways through the cons wall but it's going to look rather naff & duct runs over 3 metres can be problematic unless you have a really good extract fan. You could fit a recirculation hood over the cooker to take car of grease etc. & fit a wall mounted fan into another external wall but the required extract rate is higher in order to meet Building Regs. not a good solution IMO.
