- Joined
- 10 Sep 2004
- Messages
- 18
- Reaction score
- 0
- Country
I am putting in a dedicated supply for my dual fuel range cooker. The electric power consumption at full load is 4.5kW. I am putting in a 6.0mm supply direct from the consumer unit to a cooker switch (45Amp + 13A socket). I have some questions with regards to this installation that I would really appreciate answers to.
Is there a maximum distance the cooker socket can be from the cooker as with boilers?
The cooker switch will be located above the work surface about 200mm up the tiled wall. The kitchen floor is floorboards so the supply cable will run under the floor from the consumer unit and up the wall (buried in the plaster in conduit) to the cooker switch. I then need to get from the cooker switch back down to under the work surface where I was going to place a connection unit to allow me to wire in cooker flex. Is this a good way of doing this or is there a simpler / more professional way of doing this? Can I run a cable from the cooker unit back down parallel to the supply cable? Am I in breach of any regulations by locating the connection unit vertically below the cooker switch (about 1m below)?
