I thought this might be simple. I attached the cord with a yellow and a white connection from the camera to the DVD recorder but got a message that the camera was not connected. It was but I don't know why the message. Any ideas anyone please?
Thank you for your help Chris. It was in the input sockets. I have had a fiddle around and put the DVDR on to Line 2, saw the tape on the TV, pressed 'record' on the DVDR and it recorded onto the hard drive. Problem is it had recorded faster than it should. It may be that the 8mm tape was filmed on an old Sanyo analogue camcorder which no longer works and I was recording the tape from a digital camera. I bought a similar but slightly later Sanyo model on Amazon but that does not have the cable with the yellow and white links each end. I've googled but haven't found the suitable cable yet. Perhaps there is a setting on the DVDR about speed. I'll keep trying.
