Cost and recommend supplier
29 Nov 2005
Manchester
Hello, iam planning to do some loft insulation using fibre glass rolls. Anyone any idea how much this will/should cost per m2?
Any one recommend a supplier?
Just spotted your thread and thought I would add my 10p worth - only because I was in the local B & Q depot today buying loft insulation (3 rolls for £9) though I can't see this offer on their website. EDIT: Just read the info on the roll, it's 'DIY Top-up loft roll' 200mm thick, R value 4.5, length 4900mm, width 1100mm, area 4.4m2. Bar code says 5 012061 825145
What might also be of interest is that B & Q are currently running a promotion with British Gas whereby they are offering to supply and fit loft insulation to your home for £198.
They are also offering cavity wall insulation for the same amount of money £198.
For info I've booked the cavity wall insulation via their website.
Worth noting that if you're over 70 you can get this all done for free - contact either your gas or electric supplier or your council for more info.
