cost of electricity
8 Nov 2004
is there an easy way of calculating the ammount an electrical item will cost to run per hour
thanks
bill osborne
That only works if its on on 100% of the time. So a 3kw oven will not be using 3kw all the time, but a 1Kw electric radiant fire bar will be.
So its a about thermostat as well.
Also, most utility companies charge two different rates for electricity, which makes the calculations easy(?) :cry:
