Crack stitching kit to repair garden wall
I was thinking to use filler to close the crack and then decorate. Then I thought that The crack will appear again. Is there any special resin I can use that it will do better work than just concrete?
Ps, I know that best way is to demolish and build a new wall but it is too much for the moment...
so far so good...a very small hairline crack appeared again after a few months but that's all. It has stopped there and only if you look look carefully you notice it.
No it is so small it does not show from 1 meter. But I have to treat it in case water goes in frost conditions and opens up. We did not have frost this winter so I will do the next mhiths. It is mostly a decorative...and is stable for last years.
