I have had a number of walls and ceilings skimmed over the past 2 years. The skim has covered old plaster that was past its best, plenty of lumps, bumps and cracks. In some areas plasterboard has been used then skimmed. My question is about cracks appearing in the new plaster. The cracks are at max 1-2mm most are hairline. I have read a few posts on this but wanted to confirm a few things.
1. I have some walls that have hairline cracks and others that have none. I know that temp affects the plaster (expansion and contraction) but I have one wall in the kitchen that when the temp drops in the evening and the radiator has gone off the cracks appear and when the room warms up they disappear. I can't even find them. Would you do anything about this? Maybe fill the cracks when the temp drops or just leave well alone.
2. The landing ceiling was one of the first areas skimmed. In a moment of madness I decided to change the matt emulsion paint I had used for a mist coat on other walls and ceilings. The first coat on the landing ceiling I would not call a mist coat, the paint was too thick. The finish looks ok but quite a few cracks have appeared on the freeze area of the ceiling above door frames and in particular where the freeze joins the main ceiling. Do you think this has something to do with the paint? I am convinced some of the cracks are not the plaster but the paint lifting from the surface and cracking or separating.
3. I have a few cracks around door frames on the freeze of the ceiling, these are at various angles, some more eratic than others. I know door and window areas are weak points but is this something to be concerned about. Is there a simple way to fill the cracks without raking them out. I don't want my ceiling to have lots of obvious areas that you can tell have been repaired.
Cheers
Carl
Cheers
Carl
