Evening all
Excuse the terminology to start with...
I have a sealed/ pressurised (is that the same thing?) heating system where i'd like to cut into the pipes at ground floor and put stop ends on as a temporary measure until the plumber comes and installs some new rads after some alterations have been made by a builder starting on Monday. I'll then be draining down 3 rads and removing the existing pipework.
Do I need to release the pressure in the expansion vessel to start with?
One pipe (the flow) has a zone valve in near where its being cut which should make it slightly easier.
I assume I should shut all other rad valves as well as this valve.
Should I drain the radiators i'm removing first or will this not make a difference/ make it worse?! Some are at the same level, some are at first floor.
Any other tips?!
thanks.
Stuart
Any other tips?!
thanks.
Stuart
