Creda Dryer Reversair 37642
7 Jul 2007
Down
Machine makes slight thumping noise about once per revolution in both directions. Seems to be from the drum. (Drum was marked using tape but strangely noise is not repeated at same point as one would expect but seems to occur slightly more than one revolution). Rear bush/bearing looks fine. Changed anyway but no difference. Anyone any ideas please.
Check the front pads and the lip on the front of the drum. Poss worn pads or drum lip split
