Hi all
Machine has started making a loud 'rumbling' noise as it's spinning. No loss of heat or spin. I've had the sides and back off, and the noise appears to be located at or around the motor. When turning the drum by hand, it seems to click on something on each revolution of the motor (in either direction) and not drum. There's a white 'fan' attached directly behind the motor (accessed by removing the rear panel that holds thermostat. This fan appears to be ok and not touching anything. Can't see anything inside the motor (obviously not easy to see).
Any ideas?
Paul
Any ideas?
Paul
