Cut Bracing Between Floorboard Joists
fungus1487, hi again.
Interesting post
One final thing [from me at least]
I assume the projector produces heat? if so, where is the heat dissipated? does the projector self ventilate into the room it is serving or? where?
Ken.
Good point, the ventilation ports are mounted on the sides but the projector itself will be mounted just off the ceiling height (clearance of about 4 inches). The heat should dissipate into the room but it does have built in fans to help if it gets warmer.
The projector screen itself doesn't have any ventilation bar the exit for the screen to drop out of and up through. This might be a problem if we kept raising and lowering it for an hour solid but it basically activates, lowers then is dormant until it is raised again. Hopefully any heat produced by the motor is minimal but I will check, thanks.
