Dado rail - fixing on new plaster
9 May 2012
Sussex
Hi all,
I have a newly plastered room and will be no-nailing dado rails to the walls but am unsure on the best order to do this as will be painting the bottom and wall papering the top.......
1) Do I mist the all walls first?
2) Draw a centre line on wall where dado rail is to go and paint and paper up to it and then no-nail dado rails onto wall?
3) No-nails dado rail on wall after misting and then paper and paint?
4) Paint dado rails before fitting?
Advice greatly appreciated as like to get things done the most efficient way.
Regards,
Tom
For something as light as a dado then yes, you shouldn't need to have much paper under the rail anyway if you cut it accurately.
If you want to fill the small gap between the dado and the wall then that will change the order of things.
thank you all - I'll do 1,2 and 4 and then fill dado gaps with gaulk and final coat the dado rail
My gut feeling would be to glue rail on, mist the walls, paint, then paper. But then I can cut in and paper accurately anyway.
