Have had a bit of damp under our stairs (it’s open, not a cupboard). It mostly shows on old rucksacks etc that hang there for years and then we notice they’re a bit moldy!
It’s an external wall (we’re end of terrace 1930s, with solid brick wall - no cavity) and is rendered. The render is in good condition, but means I can’t see if there’s a DPC. The wall is about 150cm from the next house, so fairly sheltered.
Yesterday I took the floorboards up to see if there’s an obvious cause and noticed that there’s about 150mm patch of ground next to the wall that when you scrape away the top level of debris is a bit damp (see photo). As far as I could see this is the same along the wall, including places that don’t appear to be damp.
The bricks there read about 20% on my damp meter, compared to ~9% from the other bricks that I could see (the honeycomb walls that also support the joists). The joists are all ok and showing no sign of rot.
Is this something I need to sort? If so any ideas about what I can do? Or can I just leave it and keep an eye on it?
Also, would I be able to see the DPC from the inside?
The path on the other side of the wall is cement and probably been there for a very long time - doesn’t look to me to be too high, but as I can’t see the DPC its hard to tell.
Thanks for any answers / thoughts!
