When we moved in 18 months ago there were some brown patches on the wall in converted loft - previous owner said something along the lines of it had been damp which was fixed but the wall needed some kind of sealing coat to stop the marks coming through. Nothing felt damp or soft (this wall is dot and dabbed plasterboard against the party wall, with chimney behind in the middle).
Now, time to get around to doing something with it! I noticed very tiny bubbles around the light switch (this area is quite solid, must be a big chunk of plaster around the back box) which when pressed would express a small droplet of water. This concerned me so I started to open up the paint a bit and it started coming off in big sheets - it looks like some kind of rubber layer (maybe PVA?) was painted on the plaster before being painted and there isnt much holding it to the plaster any more. I took a picture and you can see the plaster underneath is pretty damp:
View media item 73556
So my first question is, could this be due to very old water being held in the wall between the plaster and the rubber layer? If there is something sealing in the water how long can it stay there?
10 days later (having run a dehumidifier in there quite a bit) I took another picture and it has dried out quite a lot:
View media item 73557
I guess the obvious suspect is the chimney but I did have somebody around last year and they said all looked ok with the pointing and flashing. I think I need to wait for some more big downpours to see if the damp patches come back.
Anything jump out I might have missed?
