Damp & Mould
21 Mar 2010
Cornwall
Good morning
We live in a REALLY old farm house which is cold and damp
We rent so I'm not about to do any major mending
One wall in our kitchen is very damp, mould growing and it came through the warmaline & paper that was there.
We've stripped it and were just going to re-do with the same method.
Is there any quick way to stop the mould coming back through the poly & paper?
I heard that putting tin foil over the patches might be a good idea
Cheers for any advice
Paul
tape a piece of clear plastic tightly to the wall. If water appears on the room side it is condensation, if on the wall side it is coming through the wall. You need to know the cause before you try to apply a cure.
If it is condensation, open the windows, take wet washing outside, and read http://www.diynot.com/wiki/building:condensation_in_houses
I did the plastic test last month, it's deff damp coming in.
just need a quick fix until we move next year
cheers
so why is the wall wet?
leaking gutter or downpipe outside?
penetrating rain?
damp patch at about ground level due to absence of dampcourse?
you need to find the cause before choosing a cure
Our kitchen has always had damp
We've recently had central heating installed
Damp patches are approx 8 feet from the ground, poss penetrating rain
possibly lack of maintenance on the outside, lack of gutter, etc.
I am at the brink of a possible fix...
Thompsons Damp Seal
Then Warmaline polysterene
Two layers of lining paper, one horizontal & oen vertical
or am I barking upm the wrong tree?
Can't do exhaustive research as this would cost, and the owners don't seem to care.
:evil:
if there is a gutter missing, does water run down this wall in heavy rain?
how difficult and expensive would it be to fit a new gutter?
trying to redecorate over a wet wall is doomed to failure
REALLY old farm houses usually don't have a damp course or cavities in the wall, so if it's not coming up the wall it's coming through the wall, it can also go up the wall on the out side and then go in the wall when it finds a good bridge.
Will your pocket stretch to this, Get some 2" X 1" tanalized timber and build a timber frame and stick brick layers damp course plastic to the side that's going against the wall. Attach the frame to the wall with screws and rawl plugs before you put the screw in fill the rawl plug with sealant.
If the walls are uneven as they some times are in old farm houses put wedges between the frame and the wall covering the contact face with the damp course plastic. Then put plaster board on top. It's close to tanking and will work.
Good luck
T
http://hubpages.com/hub/Painting-Tips-and-Tricks
Hi
There is no gutter / water route from this side of the house
Basically, the walls are pretty porous, if I run a hose on the wall
it gets damp on the inside, maybe takes 8 - 12 hours
Nothing major, but the walls are storing the water
Does anyone know if my idea will work?
