Hi Everyone
I am in the process of re-doing our cloakroom which apart from a splash of paint is as built in 1978. Because the soil pipe is virtually in the middle of the room I have planned to move the pan back to the wall. So far I have excavated the 4" concrete floor to 6" in depth to the level of the top of the black joint collar and removed the top section of the crock soil pipe from the collar.
I now have 2 problems which in spite of research I have not been able to solve:
1. How to repair the DPM
The floor is very hard with filler in the mix of rounded pebbles and quartz so I ended up hiring a power impact hammer. Necessarily, no matter how careful I was I ended up damaging the DPM. This was not helped by a very thin blinding layer over a mix of soil, broken chalk and flint. The DPM appears to be a clearish polythene showing aging embrittlement not only where exposed around the soil pipe top but on the the blinding layer - not what I expected.
Repair schemes say to take the floor back to 150 mm of good DPM. Frankly, I feel this will be impossible to achieve due to the nature of the materials involved unless I take out the whole ground floor and start over. There was a time when I would have used Waterproof PVA but what it says on the can now has changed.
Any suggestions would be much appreciated please.
2. Damp
The wall behind the soil pipe, single breeze internal, has been showing efflorescence for some time. Damp testing shows it to be dry now and so also the surface of the floor but the in fill is showing wet. The mains water inlet runs low along this wall also and I found a very small leak from the S/C gland and also evidence of a small but long term leak from the cistern/down pipe. Carpeted, these leaks have gone unnoticed for some time. After about 3 weeks the ground fill is still wet. I am confused - I would have thought it would perhaps have dried out by now, particularly as it has been dry here for some weeks. I have a water meter, recently fitted, so I am checking for a supply pipe leak tonight after shutting off the internal S/C. Initial indications are for a zero leak rate - no movement on the 'spinner'. The house is built on a sloping site on chalk.
Thanks - sorry, I seem to have gone on a bit.
2. Damp
