I have a basement flat in which only one wall is actually below ground. There is a damp problem which is recurring in the bedroom, presumably as moisture penetrates from the ground on the other side of the wall.
I received a quote & explanation of the work needed from a local builder....
Is this an adequate solution to the problem? To my mind this is simply going to mask/hide the problem which could get an awful lot worse without my knowing.
Does anyone have any opinions on this advise?
Oh and the estimate for this was £500.
Cheers
I suggest to solve this problem timber battens are fixed to the wall with a damp proof membrane behind them. To the battens then fix 12mm, foil-backed plasterboard floor to ceiling. This will create a a cavity wall which will then be free of damp or mould
Cheers
